Update Speed
Unlike most visual data discovery solutions, Panopticon Designer (Desktop) can handle updates to your data with incredible efficiency. This makes it particularly useful in organizations that must make informed business decisions based on large amounts of fast-changing data.
Dynamic Calculations
Panopticon Designer (Desktop) supports dynamic calculations using combinations of data from multiple data sources. For example, you can join data in an Excel spreadsheet with a large repository of complex historical data. Create and visualize calculated information using Excel-like formulas.
Efficient Perceptual Monitoring
Visualizations can allow for the monitoring of a large number of potential elements simultaneously. This requires that the display is organized so that these elements stand out by some visual variable, such as color, size, or position.
Data Grouping Based on Locality
Panopticon Designer (Desktop) manages information so that elements that are used together are grouped together on the screen. This reduces the need for query-based searching. This aspect of the system demonstrates an essential aspect of a good information visualization systems: It will help you find things you did not know you were looking for — without using search commands.
