Altair® Panopticon
Adjust Column Width in Table Visualizations
For the table visualization, the width of the columns can be automatically adjusted to fit the contents of a column or all of the columns.
Right-click on a column and then select either:
  • Adjust Column Width
The column width is adjusted.
  • Adjust All Column Widths
All of the column widths of the Table are adjusted.
Aside from selecting either of these context menu options, you can also manually drag the Left-Right arrow  to widen or reduce the width of the columns.
Hover on a column border, the Left-Right arrow displays.
Drag the arrow to the desired width.
