Software Requirements
Server software:
q .NET framework 4.7.2 32/64-bit
q SQL Server 2016/201/2019 (if the Monarch Server database is present on the local machine)
NOTE |
You have the option to deploy SQL Server Express 2019 and SQL Server Management Studio 18 (64-bit installation only). SQL Server Express is only suitable for RMS or Automator; it is not viable for instances servicing Content Server functionality. If SQL Server is not installed on the Common Components server, then a basic installation of SQLClient and SQLCMD is required. |
Operating systems:
q Windows Server 2016 (IIS 10.0 v1709)
q Windows Server 2019 (IIS 10.0 v1809) + Core Edition
Additional system software components:
The following components are installed automatically by the installation program if they are not present on the machine. You may consider installing them at the most convenient time (for example, a scheduled maintenance window) as the installation may require system reboots.
q Microsoft Access 2013 Runtime
q Microsoft SQL Command Line Utilities 11 for SQL Server (if the Monarch Server database is not present on the local machine)
q Microsoft ODBC Driver 11 for SQL Server (if the Monarch Server database is not present on the local machine)
q SQL 2017 Local DB
NOTE |
You can download SQL 2017 Local DB 64-bit from https://download.microsoft.com/download/E/F/2/EF23C21D-7860-4F05-88CE-39AA114B014B/SqlLocalDB.msi. |
Client software:
q One of the following browsers:
· Internet Explorer 11
· Mozilla Firefox v95.x+
· Google Chrome v96.x+
· Microsoft Edge (Chromium Engine) v96.x +
NOTE |
Compatibility of future browsers may require Monarch Server patches as a result of changes by browser vendors that compromise historic functionalities and behaviors. |
