Removing All System Components
If necessary, you can remove all Monarch Server components and files installed on the computer.
To remove system components
1. Run the MonarchAutomatorInstaller.exe file from your installation media, or use the Add/Remove Programs feature in the system’s Control Panel. The Monarch Server Automation Edition Installation Wizard is launched.
2. Click Uninstall. When the operation is complete, the corresponding message will appear.
3. Click Finish to exit the Installation Wizard.
