HyperCrash
To modify a Mig weld
Note:To accept selection(s), press Enter, click Yes or right-click the mouse button; or select Cancel.
1.From the Menu Bar, select Connections > Mig Weld > Modify.
2.Select only one Mig weld.
3.Click reviewGeneral-24 to display the Mig weld and to open the modification menu.
•In the Part sub-window:
Button
Behavior
selectPartBy2PointsUnmask-24
displays all the parts in the neighborhood of the selected Mig weld.
selectPartGeneral-24
pick parts in the graphic window to add them to the Mig weld definition.
selectPartByBox-24
select parts by box in the graphic window to add them to the Mig weld definition.
selectEntityFromTree-24
add the selected parts of the tree in the Mig weld definition
selectionclear-24
deselects the parts that define the Mig weld.
•In the Location sub-window, it is possible to change the Mig weld location.
4.Click Save to save the modified Mig weld; or
Click Cancel to cancel the Mig weld modification.
5.Click Close to close the menu.
Mig Weld selection
Button
Behavior
treeSelectUnselectAll-24
selects all the Mig welds
10_unselectalluncreated
selects all the uncreated Mig welds
selectGeneral-24
pick Mig weld in graphic window to select them
selectSpotweldByBox
select Mig weld by box (use the SHIFT key to use a polygon box)
pick parts in the graphic window to select all the Mig weld linked to those parts.
selectPartByBox-24
select parts by box (use the SHIFT key to use a polygon box) to select all the Mig weld linked to those parts.
Click on Mig weld in the listing window to select it. Several Mig welds from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys.
automaticGeneral-24
automatically recreate the "uncreated" Mig weld. In the message window, a message explains why this Mig weld cannot be created
