HyperCrash
To modify a clip
To modify a clip
To modify a clip
Note:To accept selection(s), press Enter, click Yes or right-click the mouse button; or select Cancel.
1.From the Menu Bar select Connections > Clip > Modify.
In the clip list, some of the clips are highlighted in red.  Those clips are called "uncreated" clips. HyperCrash designates the clips as "uncreated" when it cannot find the parts defining the clip.
2.Select only one clip from the clip list.
3.Click reviewGeneral-24 to view the selected clip.
It is possible to:
•Modify the clip selection.
•Modify the clip location.
•Modify the clip direction.
•Modify the properties.
4.Click Save to save the modifications; or
Click Cancel to cancel the modifications.
5.Click Close to close the menu.
Clip selection
Button
Behavior
treeSelectUnselectAll-24
select all the clips.
10_unselectalluncreated
select all the uncreated clips.
selectGeneral-24
pick clips in the graphic window to select them.
selectSpotweldByBox
select clips by box (use the SHIFT key to use a polygon box).
selectPartGeneral-24
pick parts in the graphic window to select all the clips linked to those parts.
selectPartByBox-24
select parts by box (use the SHIFT key to use a polygon box) to select all the clips linked to those parts.
Click on the clip line in the listing window to select it. Several clips from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys.
