HyperCrash
Setting
Setting
This is the first topic This is the last topic Expand/collapse all hidden text
Setting
This is the first topic This is the last topic JavaScript is required for expanding text JavaScript is required for the print function
How do I ...
hmtoggle_arrow1set the HyperCrash environment
The directory of the environment files is called $MCRASHDIR. This is a variable that needs to be set in the shell environment (csh format):
  MCRASHDIR = <ALTAIR_HOME>/hc/environment/RADIOSS_V4/environment_kN_mm_ms_kg/
In this directory, the following files are needed:
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  -rw-r--r--
  -rw-r--r--
  drwxr-xr-x
  drwxr-xr-x
  -rw-r--r--
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
  drwxr-xr-x
accelero
belt
bolt
connection
D01
d2m_m2d
database
defaults
dummng
dummy_database
includes
loadcase
mcrash_criteria
mcrash_preferences
mat
menu
modelchecker
modmng
monivol
option
p2m_m2p
property
safety
section
skew
spotweld
themes
thickshell
time_history
XPM
The following variables have to be defined:
$MCRASHEXE = <ALTAIR_HOME>\hc\bin\win32\mxplore
$MCRASHDIR = <ALTAIR_HOME>\hc\environment\RADIOSS_V4\environment_N_mm_ms_g\ dummy_database
(Example is in csh format.)
hmtoggle_arrow1set the HyperCrash executable
The directory of the executable files is called $MCRASHEXE. This is a variable that needs to be set in the shell environment (csh format):
MCRASHEXE = <ALTAIR_HOME>/hc/bin/<os_type>/
In this directory the following files are needed:
-rwxr-xr-x    MCrashV241***
lrwxr-xr-x    mcrash -> MCrashV241***
An alias may be used to execute HyperCrash (csh format):
       alias mcrash  $MCRASHEXE/mcrash
hmtoggle_arrow1set the Model Manager
The following types of files are necessary:
•database locations
•keywords
•loadcase file locations
Before the Model Management menu can be used, some information needs to be set in the following files:
File: $MCRASHDIR/modmng/database_main.tbl
/MODMNG/DATABASE/PRIVATE
<the full path private dabase 1>private_1.tbl
<the full path private dabase 2>private_2.tbl
/MODMNG/DATABASE/PUBLIC
<the full path common dabase 1>database_1.tbl
<the full path common dabase 2>database_2.tbl
/END
where:
•/MODMNG/DATABASE/PRIVATE is a command line.
•<the full path private dabase i> is the full path of the private database.
•<the full path common dabase i> is the full path of the common database (available for all HyperCrash users).
•private_i.tbl, database_i.tbl are the file names where the files of the database with their keywords are written.
•/END is a command line to indicate the end of the file.
File: <the full path database>database.tbl
This file contains the models which are stored in the databases with the keyword descriptions. This file can be updated from HyperCrash.
The following lines show the minimum information necessary in the database.tbl file.
/MODMNG/DATABASE/DIRECTORY
/END
where:
•/MODMNG/DATABASE/DIRECTORY is a command line.
•<the full path private database> is the path of the database, database.tbl where the models will be stored.
File: $MCRASHDIR/modmng/keyword.tbl
Nothing needs to be set in this file. This file is updated by HyperCrash.  To learn how to add keywords, see Keyword.
File: $MCRASHDIR/modmng/loadcase_main.tbl
This file contains the name and the location of the loadcase files.  This file needs to be created manually.
Example:
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/MODNMG/LOADCASE/TYPE
Front Crash
$MCRASHDIR/loadcase/front_crash.tbl
Rear Crash
$MCRASHDIR/loadcase/rear_crash.tbl
Side Crash
$MCRASHDIR/loadcase/side_crash.tbl
/END
where:
•/MODNMG/LOADCASE/TYPE is a command line.
•Front Crash, Rear Crash, Side Crash are the loadcase names (the names displayed in HyperCrash).
•$MCRASHDIR/loadcase/front_crash.tbl is the path and the file name of the Front Crash loadcase.
File: $MCRASHDIR/loadcase/front_crash.tbl
This file contains the description of the loadcase. This file needs to be created manually.
Example:
/MODMNG/LOADCASE/SCREEN_KEYWORD
Component
Model type
Crash type
/MODMNG/LOADCASE/MODEL
Engine
ENGINE  FEM     FRONT
Radiator
RADIATOR FEM    FRONT
Offset deformable barrier
ODB     FEM     FRONT
/END
where:
•/MODMNG/LOADCASE/SCREEN_KEYWORD is a command line. This is the keyword list displayed in the model list window.
•Component, Model Type, Crash type are the items of the previous command line. They are "keyword types" as defined in the file $MCRASHDIR/modmng/keyword.tbl.
•/MODMNG/LOADCASE/MODEL is a command line to start the description of the model to load.
•Engine is the displayed name of the model which must be loaded.
•ENGINE, FEM, FRONT  are the keywords to find the model in the databases. Those keywords must be defined in the file $MCRASHDIR/modmng/keyword.tbl.
•/END is a command to indicate the end of the file.
hmtoggle_arrow1set the Dummy Manager
•database locations
•keywords
Before the Dummy Management menu can be used, some information needs to be set in the following files:
File: $MCRASHDIR/dummng/keyword.tbl
This file needs to be created manually. Please see the Safety Module Reference Manual to learn how to set this file.
Example:
/DUMMNG/KEYWORD
Norm
EUROSID USSID   HYBRID_I@II
/DUMMNG/KEYWORD
Percentile
5       50      95
/DUMMNG/KEYWORD
Modeling
RIGID   FINE_MES@H      COARSE_M@ESH
/END
File: $MCRASHDIR/dummng/database_main.tbl
/END
where:
•private_1.tbl, database_1.tbl are the file names where the files of the database with their keywords are written.
This file contains the models which are stored in the databases with the keyword descriptions. This file needs to be created manually.
Default directory path definition:
where:
•/MODNMG/DATABASE/DIRECTORY is a command line.
•<the full path private database> is the path of the database private.tbl where the models will be stored.
Model file definition
/MODMNG/DATABASE/MODEL
<the full path of the model>/model_file_name
where:
•/MODNMG/DATABASE/MODEL is a command line.
•<the full path of the model> is the path where the dummy model is stored.
•model_file_name is the dummy model.
End of the file
/END
where:
