HyperCrash
Search
Search
Search
Search with Keywords
1.Select the keywords using Select / Unselect.
•Select: the selected keywords are displayed in the keyword drop-down list in red and are also displayed in the window Keywords.  Choose a word from the drop-down list to be added to the window.
•Unselect: choose an already selected keyword (in red) from the drop-down list to remove it from the Keywords window.
2.Click SEARCH in DataBase to start the search.
All the submodels in the database which are defined with the same list of keywords are displayed in the window just under with the name of the database and the keyword list.
The selected submodel is displayed in the small graphic window. Using the mouse, it is possible to rotate, zoom and move the submodel in this small graphic window.
3.Click Synchro displacement to synchronize the displacement between the small graphic window and the main one.
4.Select a model, and then click Validate to load it and continue to Import or Store and Modify the submodel.
or
Click Cancel to close the window.
Search with Scan
This function displays all the models available in the databases in the window, Database Tables.
1.Click a database to highlight it.
All the submodels from this database are displayed in the window, Model List.
2.In the Model List window, select one submodel.
The keyword list for this model is displayed in the window, Selected Model KeyWords, and the selected submodel is displayed in the small graphic window. Using the mouse, it is possible to rotate, zoom, and move the submodel in the small graphic window.
4.Select the desired submodel, and then click Validate to load it and continue to Import or Store and Modify the submodel.
or
Search with D00
Any RADIOSS input deck model (D00 file) can be loaded.
1.Select a directory in the Directories window.
2.In the File window, double-click a D00 file to load it in the small graphic window.
or
