HyperCrash
Rigid Bodies Details
1.From the Menu Bar, select Mass > Rigid Bodies Details.
There are three sub-tabs, displaying:
•the Mass of the rigid bodies
•the COG (center Of Gravity) of the rigid bodies
•the Inertia of the rigid bodies
2.Select rigid bodies by picking the rigid bodies line directly in the listing window. Several rigid bodies of this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys.
or
•Click treeSelectUnselectAll-24 to select all the subparts, parts and assemblies of the model.
or
•Click RBodiesSelectParts to select all the parts of the rigid body of the model.
or
•Click rigidBodiesGeneral-24 to select all the rigid bodies of the model.
3.Click massPrintData to print the selected rigid bodies' information from the active sub-tabs to a text file.
•Enter the name of the file in the Selection field.
•Click OK to save the file.
•Click Cancel to cancel this function.
4.Click printAllNotebooks to print the selected rigid bodies' information from all three sub-tabs to a text file.
5.Click Close to close this window.
See also
Part Mass Details
Balancing
