HyperCrash
Renumber
Renumber
Renumber
Renumber the entire the model
1.From the Menu Bar, select Mesh Editing > Renumber.
or
If the Mesh Editing panel is already open, select Renumber from the pull-down menu in the panel.
2.Choose one of the available options:
•Click Default Values to renumber from a predefined value.
•Click User Defined Values to renumber from values defined by you.
•Click Select/Unselect All Entities 10_me_selectallentitiesto select or unselect all entities.
•Click Reverse Selection of Entities 10_me_reverseselection to reverse the entities selected.
•From the objects in the detail list window, click the toggle button and set the starting value in the field, ID From: field. The To: field(s) is (are) automatically updated.
3.Click Renumber to save the changes.
4.Click Reset to cancel the changes and reset the default values.
5.Click Close to close the menu.
See also
Specific Renumber
