HyperCrash
To modify a time history part
1.From the Menu Bar, select Data History > Part > Modify.
or
If the Data History panel is open, select Part > Modify from the pull-down menu.
2.In the TH to modify list, click on the group to modify.
3.Click reviewGeneral-24 to display the time history part(s) in the graphic window.
It is possible to:
•Modify the TH part group name by setting a new name in the TH name field.
•Select or deselect parts (see Part selection).
4.Click Save to save the time history part modifications; or
Click Cancel to cancel the time history part modifications.
5.Click Close to close the menu.
