HyperCrash
To modify a time history node
1.From the Menu Bar, select Data History > Node > Modify.
or
If the Data History panel is open, select Node > Modify from the pull-down menu.
2.In the TH to modify list, click the group to be modified.
3.Click reviewGeneral-24 to display the time history node(s) in the graphic window.
It is possible to:
•Modify the TH node group name by setting a new name in the TH name field.
•Select or deselect nodes (see Node selection).
•Modify the time history node names (see Node name).
4.Click Save to save the time history node modifications; or
Click Cancel to cancel the time history node modifications.
5.Click Close to close the menu.
