HyperCrash
To modify a time history element
1.From the Menu Bar, select Data History > Element > Modify.
or
If the Data History panel is open, select Element > Modify from the pull-down menu.
2.In the TH to modify list, click the group to be modified.
3.Click reviewGeneral-24 to display the time history element(s) in the graphic window.
It is possible to:
•Modify the TH element group name by setting a new name in the TH name field.
•Select or deselect elements (see Element selection).
•Modify the time history element names (see Element name).
4.Click Save to save the time history element modifications; or
Click Cancel to cancel the time history element modifications.
5.Click Close to close the menu.
