HyperCrash
To modify a time history assembly
1.From the Menu Bar, select Data History > Assembly > Modify.
or
If the Data History panel is open, select Assembly > Modify from the pull-down menu.
2.In the TH to modify list, click the group to be modified.
3.Click reviewGeneral-24 to display the time history assembly(ies) in the graphic window.
It is possible to:
•Modify the TH assembly group name by setting a new name in the TH name field.
•Select or deselect assemblies (see Assembly selection).
4.Click Save to save the time history assembly modifications; or
Click Cancel to cancel the time history assembly modifications.
5.Click Close to close the menu.
