HyperCrash
To modify a section
To modify a section
To modify a section
1.From the Menu Bar, select Data History > Section > Modify.
or
If the Data History panel is open, select Section > Modify from the pull-down menu.
2.In the Section to modify list, click the section to be modified.
3.Click reviewGeneral-24 to display the section in the graphic window.
It is possible to:
•Modify the section name by setting a new name in the Section name field.
•Modify the section position (see Section plane normal).
•Modify the section components (see Section components).
4.Click Save to save the section modifications; or
Click Cancel to cancel the section modifications.
5.Click Close to close the menu.
