HyperCrash
To modify a relative displacement
1.From the Menu Bar, select Data History > Relative Displacement > Modify.
or
If the Data History panel is open, select Relative Displacement > Modify from the pull-down menu.
2.In the Th to modify list, click the group to be modified.
3.Click reviewGeneral-24 to display the time history element(s) in the graphic window.
It is possible to:
•Modify the TH name by setting a new name in the TH name field.
•Create new a relative displacement (see Node selection).
•Modify the relative displacement name (see Relative displacement name).
4.Click Save to save the relative displacement modifications; or
Click Cancel to cancel the relative displacement modifications.
5.Click Close to close the menu.
