HyperCrash
To modify a material
Isolating materials
1.From the Menu Bar, select Model > Material.
2.Go to the Tree window.
3.Select the material from the tree.
4.Click the displaytreeisolate-24 Isolate Tree Selection icon.
5.Go back to the Material window.
6.Click selectPartGeneral-24 to select parts.
7.Click reviewGeneral-24 to view the selected parts.
Material modification
If only one material is selected, HyperCrash will automatically open this material in order to modify it.
1.Click selectpartgeneral-24 and pick parts in the graphic window to select or deselect them.
2.Click treeAddEntity-24 to add or remove the parts from the tree selection.
3.Enter the different values in the fields of the material:
•Set the value or the material name.
•Click the toggle button to switch options ON or OFF.
•Click the button for the function to set or modify a function.
•Set the number of the function needed and click Ok.
4.Optional: for materials that include curves, click see_curve to view the curve.
A Plot Window opens.
5.Click databaseAdd-24 to save this material (as a RADIOSS input deck file):
•In the new sub-window, select the directory to save the material to (left area part).
•Enter the name of the material to save.
•Select OK to save the material or Cancel to cancel the save.
6.Click Save to save the material creation; or
Click Cancel to cancel the material creation.
7.Click Close to close the menu.
