HyperCrash
Duplicating Parts
Duplicating Parts
Duplicating Parts
Parts selection
1.From the Menu Bar, select Mesh Editing > Part > Duplicate.
or
If the Mesh Editing panel is already open, select Part > Duplicate from the pull-down menu in the panel.
2.Click selectPartGeneral-24 and pick parts in the graphic window to select or unselect parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
or
Click selectEntityFromTree-24 to select the parts selected in the tree.
3.Select one of the duplication options:
•Mesh only to duplicate only the mesh: nodes, elements, properties, materials and tree organization.
•Mesh + all options to duplicate the mesh and the all features belonging to the duplicated parts.
4.Set the position of the duplicated parts with the defined displacement node moving functions:
•with translations movenodetrans
•with rotations movenoderotate
•with multiple moves moveNodeDisplacement_10
•with symmetries moveNodeMirror_10
•with scaling movenodescale
5.Click Apply Translation to view the duplicated parts.
6.Click Save to save the part offset.
or
Click Cancel to cancel the part offset.
7.Click Close to close the menu.
