HyperCrash
To create Variables in a Connection
1.From the Variables notebook page, select the Connections tab.
The connections that can be parameterized in the current version are: spotwelds, welding line, hemming, glue, and bolts.
See List of Variables and Responses for an extensive list of all the possible connections variables.
var_connections-10
2.Select a connection using selectEntityFromTree-24. This will select the connection in the connection tree window.
Once a connection has been selected, its name and the list of its attributes are automatically displayed.
3.To create a variable:
•Activate one of the attributes by clicking the corresponding radio button.
•Enter a name in the corresponding text field.
•Click the Save button.
The variable is added to the list at the top of the Variables page.
Go to
Stochastic Analysis
Optimization Study
