HyperCrash
To create a Rigid Wall
1.From the Menu Bar, select LoadCase > Rigid Wall > Create.
2.Select the rigid wall type in the window Select RWALL type.
3.Enter a name in the field beside the Selection type window.
Rigid wall definition
Infinite plane
M0M1 defines the plane normal direction:
•Enter the X, Y and Z coordinates to define M0.
•Enter the X, Y and Z coordinates to define M1.
rwall_inf
Parallelogram
M0M1 ^ M0M2 defines the plane normal direction:
•Enter the X, Y and Z coordinates to define M2.
rwall_para
Cylinder
M0M1 defines the cylinder axis:
•Enter the cylinder diameter.
rwall_cyl
Sphere
M0 defines the sphere center:
•Enter the sphere diameter.
rwall_sph
4.Set a distance to automatically define the slave nodes.
or Select nodes using the different tools from the Selection folder.
Button
Behavior
selectGeneral-24
pick nodes in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar.
ellipse_icon
add/remove object by ellipse selection.
selectByBoxAdd-24
add nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
selectByBoxRemove-24
remove nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
10_addallnodes
add all nodes.
selectPartGeneral-24
pick parts in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar.
selectPartByBoxAdd-24
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
selectPartByBoxRemove-24
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
treeAddEntity-24
add the parts selected in the tree.
treeRemoveEntity-24
remove the parts selected in the tree.
5.Click the Properties tab and fill in the appropriate fields:
6.For the Friction parameters, select from the following:
•Click Sliding, Tied or Friction and enter the friction coefficient in the corresponding field.
7.Click Fixed to define a fixed rigid wall.
or
•Click Moving to define a moving rigid wall. In this case, it is possible to define:
othe rigid wall mass: fill in the Mass field.
othe rigid wall initial velocity: fill in the Initial Velocity, Vx, Vy, and Vz fields.
8.Click See to view the created rigid wall.
9.Click Save to save the created rigid wall; or
Click Cancel to cancel the rigid wall creation.
10.Click Close to close the menu.
Go to
Rigid Wall
