HyperCrash
To assign a stamping result
Assigned parts
1.Select one of the stamping results from the list.
2.Click reviewGeneral-24 to load the stamping result and display it in the small graphic window.
3.Click selectPartGeneral-24 and pick part(s) in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
or
Click selectPartByBox-24 to include (a) part(s) by box selection:
•The default box is rectangular.
•Use the SHIFT key to define a polygon box.
or
Click selectEntityFromTree-24 to include the part(s) selected in the tree.
Note:The selected parts are displayed in the second list window. There is one list selection for each stamping result.
4.Click Map Results.
Modify the assigned parts
Click deleteGeneral-24 to deselect the assigned part(s) and select a new one.
