HyperCrash
Cutting the Model
Cutting the Model
Cutting the Model
Submodel Definition
1.From the Menu Bar, select Process > Submodeling.
The Submodeling window appears.
hc_submodel
2.Select faces and parts to define the submodel:
Button
Behavior
selectGeneral-24
pick elements in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
selectByBoxAdd-24
add nodes by box selection. The default box is rectangular. Use the SHIFT key to define a polygon box.
selectByBoxRemove-24
remove nodes by box selection. The default box is rectangular. Use the SHIFT key to define a polygon box.
selectPartGeneral-24
pick parts in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
selectPartByBoxAdd-24
add parts by box selection. The default box is rectangular. Use the SHIFT key to define a polygon box.
selectPartByBoxRemove-24
remove parts by box selection. The default box is rectangular. Use the SHIFT key to define a polygon box.
treeAddEntity-24
add the parts selected in the tree.
treeRemoveEntity-24
remove the parts selected in the tree.
selectionClear-24
clear or cancel the selection.
3.Check the submodel selection:
Button
Behavior
displayTreeIsolate-24
view only the submodel.
highlightSelection
highlight the submodel.
highlightUnselected
highlight the remaining model.
mirrorSelection-24
reverse the selection. The selected faces become the remaining model.
reviewGeneral-24
update the display of the submodel.
calculatesubmodel
calculate the boundary of the submodel.
From the Section management window, in the Selection folder:
1.Add nodes to the submodel boundary:
Button
Behavior
selectGeneral-24
pick nodes in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
selectByBoxAdd-24
remove the nodes by box selection. The default box is rectangular. Use the SHIFT key to define a polygon box.
remove the parts by box selection. The default box is rectangular. Use the SHIFT key to define a polygon box.
treeAddEntity-24
treeRemoveEntity-24
selectionClear-24
clear or cancel the manual selection.
2.Add elements to the submodel boundary:
Button
Behavior
selectGeneral-24
pick faces in the graphic window. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
selectByBoxAdd-24
add faces by box selection. The default box is rectangular. Use the SHIFT key to define a polygon box.
remove the faces by box selection. The default box is rectangular. Use the SHIFT key to define a polygon box.
treeAddEntity-24
treeRemoveEntity-24
selectionClear-24
systemSelection-24
select three nodes to create the local skew of the section.
reviewGeneral-24
update the display of the submodel boundary.
From the Section management window, in the Property folder:
hc_submodel_mgmt
Validation
1.Click Save full model to save the full model with the section force.
•Select the full path and enter the file name in the Write full model window.
•Select the RADIOSS format output.
•Click OK to save the full model.
•In the Write D01 file window, click Write D01 to save the Engine file.
2.Click Save sub-model to save the submodel.
•Select the full path and enter the file name in the Write exported model window.
•Enter comments in the Header of D00 window and click Save Model.
•Click OK to save the submodel.
3.Click Save rem. model to save the remaining model (optional).
•Click OK to save the remaining model.
or
•Click Cancel to cancel the submodeling creation.
