HyperCrash
To create Variables in a Property
1.From the Variables notebook page, select the Prop tab. The list of all the properties used in the current model is displayed.
The types of properties that can be parameterized are: truss, beams, springs, beam-type springs, and shells. See List of Variables and Responses for an extensive list of all the possible variables in properties.
Var_prop-10
2.Select a property. There are two possible ways of doing this:
•Select a property directly by clicking one of the list items.
or
•Select a part by clicking (selectPartGeneral-24) or by tree selection (selectEntityFromTree-24). The property used by the selected part will be returned.
Note:If the property used by the selected part is also used by other parts, the program will ask whether the property should be duplicated.
oTo parameterize the property of only the selected part, answer Yes: a copy of the property will be created and assigned to only the selected part.
oTo parameterize the property of all the parts which are currently using it, answer No.
oTo view which parts are using a property, select the property in the list, and click the reviewGeneral-24 button.
3.Once a property has been selected, the list of its attributes is automatically displayed.
4.To create a variable:
•Activate one of the attributes by clicking the corresponding radio button.
•Enter a name in the corresponding text field.
•Click the Save button.
The variable is added to the list at the top of the Variables page.
Go to
Stochastic Analysis
Optimization Study
