HyperCrash
Dialog Menu Bar
Dialog Menu Bar
Dialog Menu Bar
Select Yes, No or Cancel to answer the question displayed on the Dialog menu bar which appears at the bottom of the screen.
hc_dialog_menu_bar
The following shortcuts can also be used:
•The ENTER and Y keys have the same function as Yes.
•The N key has the same function as No.
•The ESC key has the same function as Cancel.
•Right-click the mouse to accept part(s) selected.
