Visibility of Entities
All 3D entities are visible by default (except for named points), provided the model contains the entity.
The entity display options are available on the 3D view context tab, on the Display tab, in the Entities group.
| Icon | Name | Description |
| Sources | Show / hide sources, such as voltage sources, current sources and plane waves. | |
| Loads | Show / hide loads. | |
| Points | Show / hide named points. | |
| Probes | Show / hide probes, such as voltage probes and current probes. | |
| Cables | Show / hide cables. | |
| Networks | Show / hide general non-radiating networks. | |
| TX line | Show / hide non-radiating ideal transmission lines. | |
| RX antenna | Show / hide receiving antennas, such as far field receiving antennas and near field receiving antennas. |
