Gaussian Pulse (Normal Distribution)
Define a Gaussian time pulse with a normal distribution.
Figure 1. Define a Gaussian time pulse with a normal distribution.
- Time axis unit
- Specify the unit to be used for the time axis.
- Total signal duration ( )
- The total length of the signal in the specified units.
- Amplitude ( )
- The amplitude of the time signal.
- Pulse delay ( )
- The pulse delay is the time until the peak of the time signal envelope.
- Pulse width ( )
- This is the half-amplitude pulse width of the signal. The pulse width is the total length of time that the signal is above 50% of its peak value ( ).
- Number of samples
- The number of samples taken from the signal’s analytical equation.
The Fourier transform is as follows:
