Add an overlay image to a polar graph as a reference to the data cut
orientation.
Data must already be added to the polar graph for this
option to be available.
Select the polar graph where you want to add the image.
On the Display tab, in the
Image group, click the Chart image icon.
From the drop-down list select Model reference to
data cut orientation.
Under Model reference to data cut orientation, select a
far field request.
Note: This type of image is automatically updated depending on the selected data
cut for the trace.
Figure 1. The image is added to the polar graph as q reference to the data cut
orientation. On the left, phi was set to 0 degrees. On the right, phi
was set to 270 degrees and the overlay image was automatically updated
to reflect the changes.
