Launching EDITFEKO (Linux)
There are several options available to launch EDITFEKO on Linux.
Launch EDITFEKO using one of the following
workflows:
- Open EDITFEKO using the Launcher utility.
- Open a command terminal. Use the absolute path to the location where the
EDITFEKO executable resides, for
example:
/home/user/2021/altair/feko/bin/editfeko - Open a command terminal. Source the “initfeko”
3D view using the absolute path to it, for
example:
Sourcing initfeko ensures that the correct Feko environment is setup. Type editfeko and press Enter.. /home/user/2021/altair/feko/bin/initfekoNote: Take note that sourcing a script requires a dot (".") followed by a space (" ") and then the path to initfeko in order for the changes to be applied to the current shell and not a sub-shell.
