Apply a FEM modal port to a flat face on the
boundary of a FEM region (using the finite element method (FEM) solution
method).
On the Source/Load tab, in the
Ports group, click the
FEM modal port icon.
Figure 1. The Create FEM modal port (geometry)
dialog.
Specify the port position using one of the following workflows:
- Specify the faces. Under Specify port, click
as a list of faces and use point-entry to add the
faces.
- Specify the face using three points. Under Specify
port, click as points and specify the
three corner points of the rectangular-shaped port.
In the Label field, add a unique label for the FEM modal port.
Click Create to create the FEM modal port and to close the dialog.
