Creating a Dielectric Medium (Djordjevic-Sarkar)
Create a frequency-dependent dielectric using the Djordjevic-Sarkar method. Use this method for composite dielectrics.
On the Construct tab, in the Define group, click the
Media icon. From the drop-down list, select the
Dielectric medium icon.
Figure 1. The Create dielectric medium dialog (Djordjevic-Sarkar). - In the Definition method field, from the drop-down list select Djordjevic-Sarkar.
- In the Variation of real permittivity field, enter a value for Δε.
- In the Relative high frequency permittivity field, enter a value for ε∞.
- In the Conductivity (S/m) field, enter a value for σ.
- In the Lower limit of angular frequency field, enter a value for ω1.
- In the Upper limit of angular frequency, enter a value for ω2.
- [Optional] Specify the magnetic properties of the dielectric.
- [Optional] In the Mass density (kg/m^3) field, enter a value for ρ.
- In the Label field, enter a unique label for the dielectric.
- Click Create to create the dielectric and close the dialog.
