Geometry Highlighting for Applied Solution Methods
Before running the Solver, you can verify that the correct
solution settings are applied to the geometry. Use the tool to highlight all the relevant geometry
in the 3D view with a specific solution method applied.
The following solution parameters can be highlighted in the 3D view (while
the display of all other geometry is semi-transparent):
PO faces
RL-GO faces
UTD faces
Faces with thin dielectric sheets
Faces and wires with coatings
Impedance sheets
Windscreen reference
Windscreen solution elements
VEP regions
FEM regions
Faces containing planar Green's function apertures
Parts solved with the numerical Green's function
Characterised surfaces
On the Solve/Run tab, in the
Validate group, click the View by solution icon.
