Using the Data Source Toolbar
Several data sources have a toolbar:
Click on any of the following icons:
Icon |
Description |
A new column entry displays. Enter or select the following properties:
· Source The column name of the source schema. · Target The column name of the target schema. · Type The data type of the column. Can be a Text, Numeric, or Time. |
Check
the topmost |
Check
the |
Allows you to select an output topic in the drop-down list.
Click OK. The schema of the selected output topic is displayed. |
Tests if the connection to the output connector is successful. If successful, a confirmation message displays.
Click OK. Otherwise, an error prompt displays.
Click Close and fix the connection error. |
to select all
data source column entries.
of
a data source entry or check the topmost
to
select all column entries and click
to
delete.
