Using the Hosted Altair Units License in the Panopticon Streams Server
Using the Hosted Altair Units licensing will support simplifying the license management by removing all manual aspects of emailing license files, extending evaluation periods, among others.
In addition, Hosted Altair Units licensing will help small to medium deployment customers who do not want to host on-premise license server.
Before using the Hosted Altair Units license type in the Panopticon Streams Server, it is required to configure certain properties in the Streams.properties file located in the AppData folder or c:\streamsserverdata:
Property |
Licensing |
Attribute |
license.hwu.hosted |
Description |
Boolean stating if you wish to use Hosted or Local Altair Units licensing. Set to true if you wish to use hosted licensing. |
Default Value |
false |
Property |
Licensing |
Attribute |
license.hwu.hosted.authorization.username |
Description |
Username to the Altair One account. |
Default Value |
Property |
Licensing |
Attribute |
license.hwu.hosted.authorization.password |
Description |
Password to the Altair One account. |
Default Value |
Property |
Licensing |
Attribute |
license.hwu.hosted.authorization.token |
Description |
An authorization token generated through the Altair One admin portal. Used to authorize a machine to the Hosted Altair Units system. |
Default Value |
NOTE |
· To use the Hosted Altair Units licensing, set the following properties: license.hwu.hosted=true license.mode=HWU license.hwu.operating.system= WIN_X64 authentication.required=true license.hwu.uri=6200@localhost license.hwu.version=20.0 · Add the Panopticon application to your Altair One account.
To authorize the machine against the Hosted Altair Units system, you have two options.
Option 1
If you wish to generate the authorization token through Altair One:
1. Log on to Altair One (https://admin.altairone.com) then navigate to User Profile -> View My Authorized Machines -> Generate Auth Code (up in the right corner).
2. Paste the generated code into the license.hwu.hosted.authorization.token property in the Streams.properties file.
3. Start the server.
Option 2
To eliminate token generation on your own:
1. Enter your Altair One credentials into the license.hwu.hosted.authorization.username and license.hwu.hosted.authorization.password properties in the Streams.properties file.
2. Start the server.
NOTE |
· If a token is entered, this will be tried first. If the token was invalid or not present, and credentials are present, the credentials will be used to authorize the machine towards the Hosted Altair Units system. · A working Internet connection is required to use Hosted Altair Units licensing. · If you don’t have an Altair One account, you can sign up for a free trial and that will allow you to test the product for 14 days.
