Altair® Panopticon
Creating a New Application
A user with a Designer role can create new applications to folders or subfolders to which they have permission.
1.     On the Applications tab:
·         click  on the toolbar
·         right-click on a folder or subfolder and select New Application.
The New Application dialog displays.
2.     Enter the Name of the application and click .
The Application page displays with the following sections. Initially, the Operator Settings pane is displayed.
Clicking  displays the Metrics pane:
Clicking  displays the Data Preview pane. Note that you need to save and  run the application to preview the data.
Section/Panel
Application Name
Name of the application. Click the  button to go back to the Applications listing page.
Error Validation
After saving the changes in the application, this allows error validation. If there are definition issues (red node) or if there is no traffic on the topic (yellow node), you can click  to help fix the errors.
If there are no issues,  is no longer displayed in the Application page.
Add Operator
The available operators that can be added in the application.
Delete Operator
Delete the selected operator.
Save
Save the changes made in the Application page.
Save Options and Properties
Allow saving of changes made in the application or saving another copy. It also displays the application properties as well as adding new ones.
Expand Graph
Expand the Graph panel.
Stop Application
Stop the execution of the application.
Run Application
Run or execute an application.
Graph
Display the nodes and edges of the application model. It allows single node selection.
View Metrics
Display the throughput of the selected nodes (total and current message rates) in the Metrics panel. When the application is running, the metrics data are refreshed.
Data Preview
Display the retrieved query or table in the Data Preview panel.
Maximize
Expand the Operator Settings, Metrics, or Data Preview panel.
View Operator Settings
When an operator has been added or a node is selected in the application graph, the corresponding operator settings are displayed in the Operator Settings panel to allow editing.
When the application is running, the operator settings are displayed but are not editable.
Schema
Display the preview of the data.
