Altair® Panopticon
Header
It is possible to use a web-facing Panopticon Visualization Server behind a proxy server that will handle the authentication of users. The proxy server forwards the name of the user and roles to the Panopticon Visualization Server as HTTP headers for every request.
For requests where headers are blank or missing, they are treated like anonymous requests while requests where the user HTTP header are valid are treated like authenticated requests with that specific username.
Requests from the proxy server are fully trusted and checks are no longer performed at the Panopticon Visualization Server with regard to the validity of the username. The authorization on workbooks and administration will work as usual.
To activate the Header authentication, add or update the following properties in the Panopticon.properties  file:
authentication.type=HEADER
authentication.header.role.delimiter=,
authentication.header.roles={roles header}
authentication.header.rolesdynamic={dynamic roles header}
authentication.header.username={userid header}
For example:
authentication.header.roles=X-Roles,X-Company
authentication.header.rolesdynamic=watcher,role_for_{X-Company}
authentication.header.username=X-User
