Properties: Panopticon
The Panopticon.properties file located in the PanopticonAppdata folder (i.e., c:\vizserverdata), contains majority of properties for controlling the configuration of the Panopticon Visualization Server. The following properties can be overridden by updating the file.
Property |
Access |
Attribute |
access.administrator.groups |
Description |
The role that is mapped to the administrator group. |
Default Value |
admin |
Property |
Access |
Attribute |
access.default.roles |
Description |
The default roles applied to all users of the server. For example, if access.default.roles=DESIGNER,ADMINISTRATOR and a user with a VIEWER role logs on to the server, then the user will simultaneously have a VIEWER, DESIGNER, and ADMINISTRATOR roles. However, if no default roles are wanted, then leave the property blank. NOTE: The roles that can be assigned in this property can only be ADMINISTRATOR, VIEWER, ANONYMOUS, and/or DESIGNER. This property is case sensitive. |
Default Value |
VIEWER |
Property |
Access |
Attribute |
access.designer.groups |
Description |
The role that is mapped to the designer group. |
Default Value |
designer |
Property |
Access |
Attribute |
access.list.delimiter |
Description |
The value delimiter to use when parsing access groups. Examples: access.list.delimiter=, access.administrator.groups=group1,group2
The groups are mapped to {'group1', 'group2'}
access.list.delimiter=, access.administrator.groups=group1;group2,group3
The groups are mapped to {'group1;group2', 'group3'}
access.list.delimiter=; access.administrator.groups=group1;group2,group3
The groups are mapped to {'group1', 'group2,group3'} |
Default Value |
',' (comma) |
Property |
Access |
Attribute |
access.viewer.groups |
Description |
The role that is assigned to the viewer group. |
Default Value |
Property |
Alert |
Attribute |
alert.creation.only.by.administrators |
Description |
Enable or disable whether only the Administrators can create alerts. |
Default Value |
false |
Property |
Alert |
Attribute |
alert.detailed.logging |
Description |
Enables or disables extra alert logging. |
Default Value |
false |
Property |
Service authentication level |
Attribute |
authentication.domain |
Description |
The default domain information for user authentication. |
Default Value |
Property |
Authentication: Filter Token |
Attribute |
authentication.filter.authenticate.token |
Description |
Applies only if authentication.type is set to FILTER or is blank. If this property is set to true, the server will validate the token on incoming requests. If set to false, it ignores the token and authenticates based on the rest of the request instead. |
Default Value |
false |
Property |
Authentication: Header |
Attribute |
authentication.header.role.delimiter |
Description |
The delimiter used to separate the roles. Example: role1,role2,role3 |
Default Value |
, (Comma) |
Property |
Attribute |
authentication.header.roles |
Description |
The name of the header that contains all the roles. |
Default Value |
Property |
Attribute |
authentication.header.rolesdynamic |
Description |
Supports the ability to create dynamic roles using free form patterns or string replacement. To create dynamic roles, use '{header value to be used}'. Example: authentication.header.rolesdynamic={HEADER_ROLES},financials,role_for_company_{HEADER_COMPANY}
Given this table:
Then the roles to create the authentication token will be the following: · designer · watcher · financials · role_for_company_industrials role_for_company_consumers |
Default Value |
Property |
Attribute |
authentication.header.username |
Description |
The name of the header that contains the username |
Default Value |
Property |
Attribute |
authentication.header.validate.token |
Description |
If set to true, the authentication will validate the token. If set to false, the authentication of every request will be based on headers. |
Default Value |
Property |
Authentication: Logout |
Attribute |
authentication.logout.redirect.url |
Description |
Takes a URL as a parameter. Clicking the logout button redirects the user to the specified URL. If this property is not set, user will be returned to the start page of Panopticon. |
Default Value |
Property |
Authentication: OAuth 2.0 |
Attribute |
authentication.oauth2.client.id |
Description |
The ID of the OAuth 2.0 client. |
Default Value |
Property |
Attribute |
authentication.oauth2.client.secret |
Description |
The secret used by the OAuth 2.0 client. |
Default Value |
Property |
Attribute |
authentication.oauth2.identity.attribute.roles |
Description |
The attribute that will be extracted from the identity response and used as the role. |
Default Value |
Property |
Attribute |
authentication.oauth2.identity.attribute.roles.pattern |
Description |
Takes regex used to extract the roles from the OAuth 2.0 server identity response. For example, the returned string: cn=admin,ou=groups,dc=openam,dc=openidentityplatform,dc=org,cn=designer,ou=groups,dc=openam,dc=openidentityplatform,dc=org contains two roles, admin and designer The regex to extract the roles is cn=([^,]+). |
Default Value |
Property |
Attribute |
authentication.oauth2.identity.attribute.username |
Description |
The attribute that will be extracted from the identity response and used as the username. |
Default Value |
Property |
Attribute |
authentication.oauth2.identity.url |
Description |
The URL to the REST service that provides details about the authenticated user. |
Default Value |
Property |
Attribute |
authentication.oauth2.login.callback.url |
Description |
The callback URL. The URL should be the same as one of the specified callback URLs used by the client. The URL should refer to the Panopticon Visualization Server |
Default Value |
Property |
Attribute |
authentication.oauth2.login.redirect.url |
Description |
Redirects the user to the specified URL after successfully logging in. This property can be left blank, in which case the user is redirected to the URL they requested to access. |
Default Value |
Property |
Attribute |
authentication.oauth2.login.response.type |
Description |
The response type. The only response type that is currently supported is code. |
Default Value |
Property |
Attribute |
authentication.oauth2.login.scope |
Description |
The requested scope. |
Default Value |
Property |
Attribute |
authentication.oauth2.login.state |
Description |
The requested state. |
Default Value |
Property |
Attribute |
authentication.oauth2.login.url |
Description |
The URL to the OAuth 2.0 login resource. |
Default Value |
Property |
Attribute |
authentication.oauth2.logout.redirect.url |
Description |
Logging out revokes the token from the authentication server if the property authentication.oauth2.logout.url is set to the revocation URL. If this property is not set, the server will only remove its own token. If none of these properties are set, the server will attempt to redirect to the start page of the Panopticon when logging out. |
Default Value |
Property |
Attribute |
authentication.oauth2.logout.url |
Description |
The URL to the OAuth 2.0 logout resource. |
Default Value |
Property |
Attribute |
authentication.oauth2.token.method |
Description |
The method on how the token should be retrieved. Supported values are QUERY, BODY, and HEADER. |
Default Value |
Property |
Attribute |
authentication.oauth2.token.url |
Description |
The URL to the OAuth 2.0 token resource. |
Default Value |
Property |
Attribute |
authentication.required |
Description |
The property that will make the authentication required. It will force the user to login in order to use any of the services provided by the server. |
Default Value |
true |
Property |
Attribute |
authentication.role |
Description |
The authentication role. |
Default Value |
Property |
Authentication: SAML |
Attribute |
authentication.saml.assertion.roles |
Description |
User attribute for roles configured in the IdP. |
Default Value |
Example |
authentication.saml.assertion.roles=roles |
Property |
Attribute |
authentication.saml.assertion.username |
Description |
User attribute for username configured in the IdP. |
Default Value |
Example |
authentication.saml.assertion.username=name |
Property |
Attribute |
authentication.saml.assertionconsumerservice.url |
Description |
The
URL to the Panopticon assertion consumer service. Example: http://localhost:8080/panopticon/server/rest/auth/login |
Default Value |
Example |
authentication.saml.assertionconsumerservice.url=http://localhost:8080/panopticon/server/rest/auth/login |
Property |
Attribute |
authentication.saml.certificate.name |
Description |
The name of the certificate used to validate signature and/or sign outgoing SAML messages |
Default Value |
Example |
authentication.saml.certificate.name=saml-cert |
Property |
Attribute |
authentication.saml.certificate.password |
Description |
The password of the certificate used to validate signature and/or sign outgoing SAML messages. |
Default Value |
Property |
Attribute |
authentication.saml.challenge.required |
Description |
This property determines whether the IdP-first authentication with SAML is enabled or not. To enable, set this property to false. |
Default Value |
true |
Property |
Attribute |
authentication.saml.identityprovider.certificate.file |
Description |
Takes a file path to a certificate file that contains the IdP’s public key. |
Default Value |
Property |
Attribute |
authentication.saml.identityprovider.logout.url |
Description |
The URL to the IdP logout service. |
Default Value |
Property |
Attribute |
authentication.saml.identityprovider.signature.validation.required |
Description |
Specifies whether to require a valid IdP signature to be present on the SAML response. Default value is false. |
Default Value |
false |
Property |
Attribute |
authentication.saml.identityprovider.url |
Description |
The URL to the IdP login service. |
Default Value |
Example |
authentication.saml.identityprovider.url=https://192.168.99.100:443/simplesaml/saml2/idp/SSOService.php |
Property |
Attribute |
authentication.saml.keystore.file |
Description |
The location of the Keystore file that contains the certificate. |
Default Value |
Example |
authentication.saml.keystore.file=D:/SAML/mykeystore.jks |
Property |
Attribute |
authentication.saml.keystore.password |
Description |
The password to the Keystore file. |
Default Value |
Property |
Attribute |
authentication.saml.keystore.type |
Description |
The key store type. Possible values are JKS, JCEKS, PKCS12. |
Default Value |
JKS |
Property |
Attribute |
authentication.saml.login.redirect.url |
Description |
Default Value |
Property |
Attribute |
authentication.saml.logout.redirect.url |
Description |
Redirects the user back to the specified URL after logging out. This is mainly used with a proxy. In which case, the Panopticon Visualization Server does not know the endpoint which the user is going towards to, and therefore cannot redirect the user back to the Overview page. If you are using OpenAM this is required, otherwise this property can be left blank. |
Default Value |
Property |
Attribute |
authentication.saml.openam.meta.alias |
Description |
The meta alias for the IdP if you are using OpenAM. |
Default Value |
Property |
Attribute |
authentication.saml.protocolbinding |
Description |
Protocol binding for the use of SAML authentication. Possible values are HTTP-Redirect, HTTP-POST, HTTP-Artifact, HTTP-POST-SimpleSign, or SOAP. |
Default Value |
HTTP-Redirect |
Property |
Attribute |
authentication.saml.provider |
Description |
The IdP provider. Possible values are OPENSAML, OPENAM. |
Default Value |
OPENSAML |
Property |
Attribute |
authentication.saml.serviceprovider.id |
Description |
The ID of the service provider configured in the IdP. |
Default Value |
Example |
authentication.saml.serviceprovider.id=DwchFrontLocal8080 |
Property |
Service authentication login request |
Attribute |
authentication.timeout.callback |
Description |
The timeout (in milliseconds) for the user between initiated login and callback. The default value is five minutes. |
Default Value |
300000 |
Property |
Authentication: Token |
Attribute |
authentication.token.cookie |
Description |
The name of the cookie used to store the authentication cookie. Must be unique for each server instance on the host. |
Default Value |
ptoken |
Property |
Attribute |
authentication.token.cookie.httponly |
Description |
This property determines how the browser will treat the cookie. If set to true, the cookie will be stored in the browser as a HttpOnly cookie and will not be available to the JavaScript. If set to false (default), the cookie will be stored in the browser as https and will be accessible to the JavaScript. |
Default Value |
false |
Property |
Attribute |
authentication.token.cookie.samesite |
Description |
Used by browsers to control the behavior of same or cross origin requests. There are three possible values. Lax, Strict, and None. Please refer to browser specific documentation for its usage. |
Default Value |
Lax |
Property |
Attribute |
authentication.token.cookie.secure |
Description |
The property determines how the browser will treat the cookie depending on the security of the connection. If set to true, when the browser receives a secure cookie (HttpOnly cookie), you will not be able to transmit it unless the connection is secure. |
Default Value |
false |
Property |
Attribute |
authentication.token.domain |
Description |
Specifies the token cookie domain. |
Default Value |
Property |
Attribute |
authentication.token.in.login.response.body |
Description |
This property determines if the REST login response body should contain a token info. NOTE: Does not affect the SOAP login response body. |
Default Value |
false |
Property |
Attribute |
authentication.token.persistence |
Description |
This property is used to determine if the token should persist if the browser is closed or if it should only last while the browser is open. There are two possible values: PERSISTENT and SESSION. PERSISTENT will persist the token in the browser even if the browser has been closed and reopened. SESSION will remove the token from the browser if it is shutdown. IMPORTANT: After modifying the property value to SESSION, ensure to clear the AppData/Token folder before starting the server. |
Default Value |
PERSISTENT |
Property |
Attribute |
authentication.token.refreshable |
Description |
This property determines if the token can refresh itself. The Web client can identify if the token is about to expire and then request a new token with the existing token. A token is refreshable if the property is set to true. The token will expire and invalidate the user session if the property is set to false. |
Default Value |
true |
Property |
Attribute |
authentication.token.secret |
Description |
The secret is used to sign the token. The secret will be auto-generated when the server starts for the first time. NOTE: This value should be kept a secret. |
Default Value |
Auto-generated |
Property |
Attribute |
authentication.token.validity.seconds |
Description |
The number of seconds that the token should be valid. |
Default Value |
604800 |
Property |
Attribute |
authentication.type |
Description |
The type of the authentication mechanism that will be used on the Server. |
Default Value |
BASIC |
Property |
Bookmark Administration |
Attribute |
bookmark.administration.only.by.administrators |
Description |
Set to true if only Administrators should be able to manage bookmarks. |
Default Value |
false |
Property |
Cache |
Attribute |
cache.data.datasource.enabled |
Description |
Enable or disable the caching of the data source. |
Default Value |
true |
Property |
Cache |
Attribute |
cache.data.datasource.size |
Description |
The data source cache size. |
Default Value |
100 |
Property |
Cache |
Attribute |
cache.data.datasource.type |
Description |
The data source cache type.Allowed values: MEMORY, NONE |
Default Value |
MEMORY |
Property |
Cache |
Attribute |
cache.data.datatable.enabled |
Description |
Enable or disable the caching of the data table. |
Default Value |
true |
Property |
Cache |
Attribute |
cache.data.datatable.size |
Description |
The data table cache size. |
Default Value |
100 |
Property |
Cache |
Attribute |
cache.data.datatable.type |
Description |
The data table cache type.Allowed values: MEMORY, NONE |
Default Value |
MEMORY |
Property |
Cache |
Attribute |
cache.data.query.enabled |
Description |
Enable or disable the caching of data query. |
Default Value |
true |
Property |
Cache |
Attribute |
cache.data.query.size |
Description |
The data query cache size. |
Default Value |
100 |
Property |
Cache |
Attribute |
cache.data.query.type |
Description |
The data query cache type.Allowed values: MEMORY, NONE |
Default Value |
MEMORY |
Property |
Cache |
Attribute |
cache.plugin.id |
Description |
The ID of the plugin that will be used to store data extracts. Possible values: BinaryTableFile-Cache. |
Default Value |
BinaryTableFile-Cache |
Property |
Cache |
Attribute |
cache.purge.condition |
Description |
Defines the condition for when the cache will be purged. Allowed values: NONE, MEMORY |
Default Value |
MEMORY |
Property |
Cache |
Attribute |
cache.purge.condition.memory.threshold |
Description |
Defines a percentual memory threshold for cache purging, when the cache.purge.condition = MEMORY. |
Default Value |
80 |
Property |
Cache |
Attribute |
cache.purge.enabled |
Description |
Enables scheduled cache purging. |
Default Value |
true |
Property |
Cache |
Attribute |
cache.schedule.clear.enabled |
Description |
Enable the cache clearing schedule. This is scheduling the clear cache operation which will remove all the expired cache entries. |
Default Value |
true |
Property |
Cache |
Attribute |
cache.service.enabled |
Description |
Enables or disables the service cache. |
Default Value |
true |
Property |
Cache |
Attribute |
cache.service.type |
Description |
The service cache mechanism being used. |
Default Value |
IN_MEMORY |
Property |
Client Cache |
Attribute |
client.cache.control.age.max |
Description |
Controls the cache-control max-age header for static content. |
Default Value |
31536000 |
Property |
Client Data |
Attribute |
client.data.load.transport |
Description |
Configure the transportation protocol for loading data from the Web client. Possible values: WEBSOCKET, LONG_POLLING. NOTE: This property has been deprecated. Refer to Setting the Transportation Protocol for more information. |
Default Value |
WEBSOCKET |
Property |
Server Cluster |
Attribute |
cluster.bully.bind |
Description |
The URL of the server in bully mode. This should be the URL to the panopticon server web application on the server itself, by which is reachable from the other servers. |
Default Value |
Property |
Server Cluster |
Attribute |
cluster.bully.boot |
Description |
Comma-separated list of server URLs in bully mode. At least one of these servers should be running at all time for the bully mode to work correctly. The URLs should be the same as the cluster.bully.bind value on each boot server. |
Default Value |
Property |
Server Cluster |
Attribute |
cluster.bully.id |
Description |
The unique server ID in bully mode. Can be any string, but do not change it after the server has participated in a cluster -- the other servers will store it and expect it to identify the same server in the future. The running server with the lowest ID lexicographically will be leader. |
Default Value |
Property |
Server Cluster |
Attribute |
cluster.fixed.leader |
Description |
The leader URL in fixed mode. This should be the URL to the panopticon server web application on the preset leader server, by which it is reachable from the follower servers. Leave blank on the leader server itself. |
Default Value |
Property |
Server Cluster |
Attribute |
cluster.kubernetes.id |
Description |
Set to the name of the pod that runs the container. |
Default Value |
(blank) |
Property |
Server Cluster |
Attribute |
cluster.kubernetes.label_selector |
Description |
Standard Kubernetes label selector that should only match the pods that are running the server. |
Default Value |
Property |
Server Cluster |
Attribute |
cluster.kubernetes.peer_path |
Description |
Path to the web application on each server. For example, "panopticon/", or "/" if you have deployed to Tomcat's root. |
Default Value |
Property |
Server Cluster |
Attribute |
cluster.mode |
Description |
NONE (default), FIXED, BULLY, or KUBERNETES |
Default Value |
Property |
Server Cluster |
Attribute |
cluster.shared.secret |
Description |
Any alphanumeric string. Secret used to encrypt a challenge in peer-to-peer communication handshake. Needs to be the same, and non-empty, on all connected servers. |
Default Value |
Property |
Server Cluster |
Attribute |
cluster.shared.store.shared_directory.path |
Description |
Shared store location in SHARED_DIRECTORY mode. This path must be reachable by all connected servers, and must point to the same physical directory on all of them. |
Default Value |
Property |
Server Cluster |
Attribute |
cluster.shared.store.type |
Description |
PRIVATE_DIRECTORY (default) or SHARED_DIRECTORY The shared store is used to store information that should be synchronized between servers but is not content, for example authentication tokens. If you have a tightly-coupled cluster, e.g., behind a load balancer, it is recommended that you configure this as a shared directory. |
Default Value |
Property |
Host Lookup |
Attribute |
connector.kdb.host.lookup.script |
Description |
Full path of the shell script file that is accessible on the server. When set, before making a new kdb+ connection, this script is executed to get the host info. This property helps in overriding connection details entered inside the kdb+ connector UI centrally, and may help when different authentications are set at kdb+ like Kerberos/Custom etc. The output of this script is expected to be a JSON object like below. { "host": "localhost", "port": 5001, "username": "", "password": "" } NOTE: Starting with the 21.2 release, the the kdb+ connection pool feature of Panopticon (kdb.connection.pool.xx) can be used together wth the host lookup. So any new connection request from the pool, will first execute the script set here, to get the host info before the pool is looked up for available connections. Examples: · For Windows connector.kdb.host.lookup.script=E://Data/host.bat · For Linux connector.kdb.host.lookup.script= /etc/panopticon/appdata/host.sh
Default Value |
Property |
Host Lookup |
Attribute |
connector.kdb.host.lookup.script.arguments |
Description |
Delimited set of arguments to be passed to the script when it is executed. ’{host},{port},{userid},{password}’ is the default value, and these parameters are mapped to respective settings in the connector UI i.e., the value entered against these settings in the connector UI are passed as arguments to the script. This property can be extended or updated if you want to pass other datatable parameters as arguments. System parameter like {_user_id} or {_workbook_folder}, if added to the data table, can also be used. If the value of some parameter is null or empty at the time of execution of the script, two single quotes are passed (‘’) against that parameter, this is to make sure that arguments count matches the arguments set at this property. |
Default Value |
{host},{port},{userid},{password} |
Property |
Host Lookup |
Attribute |
connector.kdb.host.lookup.script.arguments.delimiter |
Description |
Used to split the arguments set at above property. |
Default Value |
Property |
Host Lookup |
Attribute |
connector.kdb.host.lookup.script.timeout |
Description |
The timeout (in milliseconds) to wait for the host lookup script to run and return the host info. |
Default Value |
5000 |
Property |
Amazon Kinesis – Data Streams connector |
Attribute |
connector.kinesis.datastreams.accesskeyid |
Description |
The Access Key ID from the AWS account. |
Default Value |
Property |
Attribute |
connector.kinesis.datastreams.secretaccesskey |
Description |
The Secret Access Key ID from the AWS account. |
Default Value |
Property |
Python connector |
Attribute |
connector.python.host |
Description |
The default Python Pyro instance host address. NOTES: For connector.python.host, connector.python.password, connector.python.port, and connector.python.serializertype properties: · If set in the Panopticon.properties file, these fields will be hidden in the Python connector and will be applied to the Python transform as well. · These default Visualization Server connection properties will be applied at runtime. These default Visualization Server connection properties will override old Python connection settings. |
Default Value |
Property |
Python connector |
Attribute |
connector.python.password |
Description |
The default HMAC Key. |
Default Value |
Property |
Python connector |
Attribute |
connector.python.port |
Description |
The default Python Pyro host port. |
Default Value |
Property |
Python connector |
Attribute |
connector.python.serializertype |
Description |
The default Python serialization type. Possible values are serpent or pickle. |
Default Value |
Property |
Rserve connector |
Attribute |
connector.rserve.host |
Description |
The default Rserve host address. NOTES: For connector.rserve.host, connector.rserve.password, connector.rserve.port, and connector.rserve.userid properties: · If set in the Panopticon.properties file, these fields will be hidden in the Rserve connector and will be applied to the R transform as well. · These default Visualization Server connection properties will be applied at runtime. These default Visualization Server connection properties will override old Rserve connection settings. |
Default Value |
Property |
Rserve connector |
Attribute |
connector.rserve.password |
Description |
The default password that will be used to connect to the Rserve service. |
Default Value |
Property |
Rserve connector |
Attribute |
connector.rserve.port |
Description |
The default Rserve host port. |
Default Value |
Property |
Rserve connector |
Attribute |
connector.rserve.userid |
Description |
The default user Id that will be used to connect to the Rserve service. |
Default Value |
Property |
REST Documentation |
Attribute |
documentation.enabled |
Description |
Enable or disable the OpenAPI Specification documentation for the REST interface. |
Default Value |
false |
Property |
Alert |
Attribute |
email.address |
Description |
The email address where the alert will be sent from. |
Default Value |
Property |
Attribute |
email.host |
Description |
The host name used by the email server. |
Default Value |
Property |
Alert |
Attribute |
email.password |
Description |
The email password, if available. |
Default Value |
Property |
Attribute |
email.port |
Description |
The port number used by the email server. |
Default Value |
Property |
Attribute |
email.security.mode |
Description |
The security mode used when sending emails. Possible values: NONE, SSL, TLS. |
Default Value |
NONE |
Property |
Attribute |
email.username |
Description |
Email account username. |
Default Value |
Property |
Error Message |
Attribute |
error.default.message |
Description |
Defines a generic error message override. |
Default Value |
Property |
Image export |
Attribute |
export.image.height |
Description |
The default height for an exported image. |
Default Value |
768 |
Property |
Image export |
Attribute |
export.image.width |
Description |
The default width for an exported image. |
Default Value |
1024 |
Property |
File Upload |
Attribute |
file.upload.size.max.bytes |
Description |
Limit for files size to be uploaded through the web browser (i.e., workbooks, streams applications, streams data sources). |
Default Value |
30000000 |
Property |
Copy Image |
Attribute |
image.client.timeout |
Description |
Specifies a timeout when producing an image or PDF. If it takes longer than the timeout, the process will be interrupted, and the image/PDF will not be produced. |
Default Value |
600000 |
Property |
kdb+ Connection Pooling |
Attribute |
kdb.connection.pool.max.size |
Description |
The maximum number of connections that will be kept open for reuse for each kdb+ server (among kdb+ servers that use the same username, password, TLS flag, and timeout), so that established connections can be reused when subsequent queries come in for the same server. A benefit of the connection pool is that it can reduce latency. Setting this property to 0 disables the connection pool. |
Default Value |
10 |
Property |
Attribute |
kdb.connection.pool.ttl |
Description |
Time to live in milliseconds for each connection instance created. |
Default Value |
30000 |
Property |
Licensing |
Attribute |
license.hwu.hosted |
Description |
Boolean stating if you wish to use Hosted or Local Altair Units licensing. Set to true if you wish to use hosted licensing. |
Default Value |
false |
Property |
Licensing |
Attribute |
license.hwu.hosted.authorization.password |
Description |
Password to the Altair One account. |
Default Value |
Property |
Licensing |
Attribute |
license.hwu.hosted.authorization.token |
Description |
An authorization token generated through the Altair One admin portal. Used to authorize a machine to the Hosted Altair Units system. |
Default Value |
Property |
Licensing |
Attribute |
license.hwu.hosted.authorization.username |
Description |
Username to the Altair One account. |
Default Value |
Property |
Licensing |
Attribute |
license.hwu.operating.system |
Description |
The operating system where the Panopticon Visualization Server is installed. Possible values are: WIN_X86, WIN_X64, MAC, LINUX_X64, or LINUX_ARM64 NOTE: If the Java bitness (e.g., 32-bit) is different from the operating system (e.g., 64-bit), it is recommended to add the Java bitness in this property (e.g., WIN_X86). |
Default Value |
Property |
Licensing |
Attribute |
license.hwu.uri |
Description |
The path where the License Server is running e.g., 6200@191.255.255.0 where the syntax is PORTNUMBER@HOST. If multiple servers are specified, use the ‘;’ semicolon separator sign for Windows and the ‘:’ colon separator sign for Linux. NOTE: If value is not set in the Panopticon.properties, the environment variable ALTAIR_LICENSE_PATH serves as the backup path and will be used. |
Example |
For Windows: license.hwu.uri=6200@192.168.5.51;6200@192.168.5.52 For Linux: license.hwu.uri=6200@192.168.5.51:6200@192.168.5.52 |
Default Value |
Property |
Licensing |
Attribute |
license.hwu.version |
Description |
Value must match the license version found in the Altair Units license file. |
Default Value |
19.0 |
Property |
Licensing |
Attribute |
license.mode |
Description |
The license mode. Possible values are: FILE or HWU. To use the Altair Units license, set this property to HWU. |
Default Value |
FILE |
Property |
Log level |
Attribute |
logger.level.file |
Description |
Controls the level that is logged to file. |
Default Value |
WARNING |
Property |
Server Metrics |
Attribute |
metrics.authorization.level |
Description |
Specifies the required authorization level to get server metrics. Available values are ANONYMOUS, VIEWER, DESIGNER, ADMINISTRATOR. NOTE: This property is case sensitive. |
Default Value |
ADMINISTRATOR |
Property |
Server Metrics |
Attribute |
metrics.collection.rate |
Description |
Specifies the rate at which metrics are collected in milliseconds. |
Default Value |
1000 |
Property |
Server Metrics |
Attribute |
metrics.file.flush.rate |
Description |
Specifies how often metrics should be saved to disk in milliseconds. Only used if the metrics.publisher.type is set to FILE. |
Default Value |
10000 |
Property |
Server Metrics |
Attribute |
metrics.memory.queue.size |
Description |
Specifies how many metric entries are stored in memory. When the number of metrics goes above the specifies value, the oldest value is removed to make room for the newest one (FIFO). Only used if the metrics.publisher.type is set to MEMORY. |
Default Value |
100 |
Property |
Server Metrics |
Attribute |
metrics.publisher.configuration |
Description |
Specifies the id for which metric publisher configuration to use. |
Default Value |
Property |
Server Metrics |
Attribute |
metrics.publisher.type |
Description |
Specifies the current metric publisher that is used. Available values are NONE, MEMORY, FILE, EMAIL, INFLUX_DB, JDBC, KAFKA, KDB, MQTT, REST, TEXT. |
Default Value |
MEMORY |
Property |
Bookmarks repository |
Attribute |
repository.import.bookmarks.paths |
Description |
Will import bookmarks from the old format into the repository. Will override any existing bookmarks inside the repository. Must be set to an absolute path. Only bookmarks for workbooks that exists inside the repository will be imported. |
Default Value |
Property |
Workbook repository |
Attribute |
repository.migrate.archive.path |
Description |
Use this property if you have an older (pre 2020) server and wish to start the new server with the same workbook content as the old one, and also to import the workbooks' change history from the old server. Set the property to the absolute path to the old server's <AppData>/Archive/ directory, delete the new server's <AppData>/.repository/ directory, and start the new server. You typically use this property with the repository.migrate.workbooks.path property. See also the section on content migration. |
Example |
C\:/vizserverdata/Archive |
Default Value |
Property |
Attribute |
repository.migrate.bookmarks.path |
Description |
Will migrate bookmarks from the old format into the repository if there are no bookmarks inside the repository yet. Set to an absolute path or to the default Bookmarks folder. Only bookmarks for workbooks that exists inside the repository will be migrated. NOTE: If you do not wish to migrate bookmarks or already have bookmarks in the repository, set this property to blank to avoid a warning on startup. |
Default Value |
Bookmarks |
Property |
Attribute |
Description |
Starting with version 21.0, data extracts are stored inside the repository. If this property is set to GlobalCaches (default value), or to an absolute path, the server will migrate data extracts into the repository on startup as long as the repository does not contain any previous data extracts. NOTE: If you do not wish to migrate data extracts or already have data extracts in the repository, set this property to blank to avoid a warning on startup. |
Default Value |
GlobalCaches |
Property |
Data Templates Repository |
Attribute |
repository.migrate.datatable.templates.path |
Description |
Will migrate data table templates from the old format into the repository if there are no data table templates inside the repository yet. Set to an absolute path or to the default Datatables folder. NOTE: If you do not wish to migrate data table templates or already have data table templates in the repository, set this property to blank to avoid a warning on startup. |
Default Value |
Datatables |
Property |
Themes repository |
Attribute |
repository.migrate.themes.path |
Description |
Will migrate themes from the old format into the repository if there are no themes inside the repository yet. Set to an absolute path or to the default Themes folder. NOTE: If you do not wish to migrate themes or already have themes in the repository, set this property to blank to avoid a warning on startup. |
Default Value |
Themes |
Property |
Attribute |
repository.migrate.workbooks.path |
Description |
Use this property if you have an older (pre 2020) server and wish to start the new server with the same workbook content as the old one. Set the property to the absolute path to the old server's <AppData>/Workbooks/ directory, delete the new server's <AppData>/.repository/ directory, and start the new server. See also the section on content migration. |
Example |
C\:/vizserverdata/Workbooks |
Default Value |
Property |
Attribute |
repository.pack.enabled |
Description |
The repository tracks all changes to all workbooks. If you have a very large number of workbooks, or have kept the repository for a very long time, the sheer number of files inside the .repository subdirectory could cause the repository to become slower. Set this property to true to have the repository pack all the files into fewer larger ones for faster access. |
Default Value |
false |
Property |
Repository |
Attribute |
repository.startup.apply.permissions.clean |
Description |
Use this property with the repository.startup.apply.permissions.path to reset all existing workbook permissions on the server before applying the template. If you set it to true, the server will remove all permissions, then give users full permissions to their private folders, and the "Everyone" group full permissions to public folders. |
Default Value |
false |
Property |
Repository |
Attribute |
repository.startup.apply.permissions.create |
Description |
Use this property with the repository.startup.apply.permissions.path to create empty workbook folders for any folders that are in the template file but do not yet exist on the server. If you don't set it to true, these folders from the template will be ignored. |
Default Value |
true |
Property |
Repository |
Attribute |
repository.startup.apply.permissions.path |
Description |
Use this property to make the server apply workbook folder permissions from a template JSON file on startup. Workbook folder permissions in the template will overwrite any existing permissions on the server. This property will not migrate permissions from an older (pre 2020) server, you need to use the PCLI convertpermissions to generate a template file from the old permissions first. See also repository.startup.apply.permissions.clean and repository.startup.apply.permissions.create. |
Default Value |
Property |
Repository |
Attribute |
repository.startup.filesystemcheck |
Description |
If set to true, server runs on startup to verify the repository integrity and reports any of the following issues: · a deleted /HEAD file, · a modified /HEAD, · a modified /refs/heads/master file, · any file deleted inside /objects/ (e.g., /objects/94/443eec118fb8bb2021071896ff7d386a9c9518), · any file modified inside /objects/. NOTE: There may be dangling files in the /objects/ directory or those that are not in use. These files are typically results of failed saves and/or sync conflicts. The check may or may not detect deleted or modified dangling files, but that is not critical. |
Default Value |
false |
Property |
Repository Import |
Attribute |
repository.startup.import.paths |
Description |
NOTE: Use this property to make the server import content at startup. This is imported on top of the existing content and will always overwrite anything that is already there. This property can be useful for example, if you have multiple servers with different content but you want the latest version of a standard set of workbooks to be deployed on all of them. This property only has effect on a stand-alone or leader server. This property is the list of paths to directories and files, separated by the system specific path separator “;” on Windows and “:” on Linux. Each directory is scanned and imported keeping its local tree structure. For example, workbooks to be imported are placed in a folder and in this property, the absolute path to that folder is specified. ADDITIONAL NOTES: · User-specific folders (e.g. “~john/”) can be targeted this way, but only if they already exist on the server. · Bundles (exz files) directly listed in the property or found in directories listed are also imported, but always to the root, with their internal structure preserved. · Files that are not legacy workbooks or bundles are ignored. · The same set of workbooks will get imported over and over (startup, user edit, restart) and for bundles (nothing changes in the history the second time), but legacy workbooks change their meta data. · The import always overwrites local changes (it resets the workbooks in the repository). Permissions are not supported, and any folders created will have “SYSTEM” as owner. |
Default Value |
Property |
Request parameter mapping |
Attribute |
request.cookie.parameters.mapping.entry.delimiter |
Description |
The delimiter that separates the configuration entries. This property will only affect incoming parameters. |
Default Value |
, (Comma) |
Property |
Attribute |
request.cookie.parameters.mapping.optional |
Description |
The parameters that could be updated with certain cookie values. This property will only affect incoming parameters. The operation will not fail if the cookie values are not present in the request. The parameters will keep their default value instead of the configured cookie value if the cookie is not present. The property should be formatted as follows: Parameter name (Value delimiter) Cookie name. |
Default Value |
Property |
Attribute |
request.cookie.parameters.mapping.required |
Description |
The parameters that are required to be updated with certain cookie values. This property will only affect incoming parameters. The operation will fail if configured cookie values are not present in the request. The property should be formatted as follows: Parameter name (Value delimiter) Cookie name. |
Default Value |
Property |
Attribute |
request.cookie.parameters.mapping.value.delimiter |
Description |
The delimiter that separates the parameter name and the cookie name. This property will only affect incoming parameters. |
Default Value |
: (Colon) |
Property |
Attribute |
request.header.parameters.mapping.entry.delimiter |
Description |
Default Value |
, (Comma) |
Property |
Attribute |
request.header.parameters.mapping.optional |
Description |
The parameters that could be updated with certain header values. This property will only affect incoming parameters. The operation will not fail if the header values are not present in the request. The parameters will keep their default value instead of the configured header value if the header is not present. The property should be formatted as follows: Parameter name (Value delimiter) Header name. |
Default Value |
Property |
Attribute |
request.header.parameters.mapping.required |
Description |
The parameters that are required to be updated with certain header values. This property will only affect incoming parameters. The operation will fail if a configured header values are not present in the request. The property should be formatted as follows: Parameter name (Value delimiter) Header name. |
Default Value |
Property |
Attribute |
request.header.parameters.mapping.value.delimiter |
Description |
The delimiter that separates the parameter name and the header name. This property will only affect incoming parameters. |
Default Value |
: (Colon) |
Property |
Response parameter mapping |
Attribute |
response.operation.parameters.mapping.entry.delimiter |
Description |
The delimiter that separates the configuration entries. This property will only affect outgoing parameters. |
Default Value |
, (Comma) |
Property |
Attribute |
response.operation.parameters.mapping.optional |
Description |
The parameters that could be updated with certain Header values. This property will only affect outgoing parameters. The operation will not fail if the Header values are not present in the request. The parameters will keep their default value instead of the configured Header value if the Header is not present. The property should be formatted as follows: Parameter name (Value delimiter) Header name. |
Default Value |
Property |
Attribute |
response.operation.parameters.mapping.required |
Description |
The parameters that are required to be updated with certain Header values. This property will only affect outgoing parameters. The operation will fail if configured Header values are not present in the request. The property should be formatted as follows: Parameter name (Value delimiter) Header name. |
Default Value |
Property |
Attribute |
response.operation.parameters.mapping.value.delimiter |
Description |
The delimiter that separates the parameter name and the Header name. This property will only affect incoming parameters. |
Default Value |
: (Colon) |
Property |
REST |
Attribute |
rest.response.error.stacktrace.included |
Description |
Include the error stack trace in REST responses. |
Default Value |
false |
Property |
Compatibility |
Attribute |
server.force_downgrade |
Description |
The server normally refuses to start if it detects that the AppData directory has been used by a server with a newer version. This is because downgrading content and other AppData files is not supported and can cause irreversable issues. You can set this property to true to force the server to start anyway, but it is strongly recommended that you do not. |
Default Value |
false |
Property |
Attribute |
Description |
The server endpoint address. This will be used to generate links in emails sent by the server, so it should be the server's or load balancer's public URL and needs to be resolvable from the email recipient's machine. For example: server.host=http://www.company.com/dashboards/ |
Default Value |
Property |
PDF and Image generation |
Attribute |
server.host.internal |
Description |
The local server endpoint address. To generate PDFs and images, the server fires up an external process which then makes HTTP calls to the server itself. This URL needs to be resolvable on the server itself. For example: server.host.internal=http://127.0.0.1:8080/panopticon/ |
Default Value |
Property |
Server |
Attribute |
server.id |
Description |
Specifies an id for the current server. The value of this property will be part of each metric entry so that it can be tied to a specific server if a server cluster is used. If no value is specified, the MAC address of the localhost network will be attempted to be used to identify the server. If this is not possible, a UUID will be generated. |
Default Value |
Property |
SOAP |
Attribute |
soap.enabled |
Description |
Enable or disable the SOAP interface |
Default Value |
true |
Property |
Data table regression testing |
Attribute |
startup.regression.datatable.exclude.folders |
Description |
Comma-separated list of folders that will be excluded in the testing. Use this property in combination with the startup.regression.datatable.include.folders property to control which workbooks to include in the testing. For example, you can set startup.regression.datatable.include.folders to "pub\\" and startup.regression.datatable.exclude.folders to "pub\\examples\\,pub\\temp\\". |
Default Value |
Property |
Attribute |
startup.regression.datatable.include.folders |
Description |
Comma-separated list of folders to test. The default is blank, which means the root folder and all workbooks will be tested. If you list folders here, then only the data tables in workbooks in these folders will be tested, unless also excluded. Folder paths should include a trailing backslash, and you need to use double backslashes since this is the escape character in Java property files. For example, to only include prod and qa\final, you should set the property to "prod\\,qa\\final\\" (without quotes). |
Default Value |
Property |
Attribute |
startup.regression.datatable.runonce |
Description |
If set to true, the server will run a data table regression test during the next startup. The property is immediately reset to false, so you need to set it to true again to run another test. NOTE: You can set the property through an environment variable if you want to force the server to run it on every startup. |
Default Value |
false |
Property |
Authorization |
Attribute |
statistics.authorization.level |
Description |
Allows users to set the authorization level for the statistics and diagnostic REST services. Possible values include: ANONYMOUS, VIEWER, DESIGNER, ADMINISTRATOR. NOTE: This property is case sensitive. |
Default Value |
ADMINISTRATOR |
Property |
Subscription |
Attribute |
subscription.broadcasting.pool.max.size |
Description |
The maximum number of threads for the broadcasting thread pools of refresh events. The default value is empty, which means that there is no limit. Any value less than 1 also means that there is no limit. When setting a max value for the thread pools, it means that the pool cannot create more than that number of threads. If there are more concurrent events handled by the thread pools than there are threads, they are queued until a thread becomes available. The thread pools are also configured to only increase the pool size if all threads are busy and a new event needs to be processed. If a thread is idle more than 1 minute, it will be removed from the pool and the size of the pool thereby decreases. Any subscription for a static data source are scheduled to refresh each X seconds (based of the refresh period of the datatable) using the TaskScheduled built in to Spring. If multiple subscriptions with the same data query tries to load data at the same time, only one thread will actually load the data. The rest of the subscriptions are queued. When the data is loaded all waiting subscriptions will be given the same data set that are then broadcasted to their respective client. |
Default Value |
Property |
Subscription |
Attribute |
subscription.compression.enabled |
Description |
Enable or disable compression and encoding of subscription broadcast messages. |
Default Value |
true |
Property |
Subscription |
Attribute |
subscription.congestion.control.enabled |
Description |
When the server loads data for a subscription, it checks that the previous data load for it has completed. If not, it might be a sign that the refresh rate is set too high on the data table. If this happens subscription.maximum.failure times in a row, the server will cancel the subscription. Set this property to false to disable this behavior. |
Default Value |
true |
Property |
Subscription |
Attribute |
subscription.data.loading.pool.max.size |
Description |
The maximum number of threads for loading thread pools of refresh events. The default value is empty, which means that there is no limit. Any value less than 1 also means that there is no limit. When setting a max value for the thread pools, it means that the pool cannot create more than that number of threads. If there are more concurrent events handled by the thread pools than there are threads, they are queued until a thread becomes available. The thread pools are also configured to only increase the pool size if all threads are busy and a new event needs to be processed. If a thread is idle more than 1 minute, it will be removed from the pool and the size of the pool thereby decreases. Any subscription for a static data source are scheduled to refresh each X seconds (based of the refresh period of the datatable) using the TaskScheduled built in to Spring. If multiple subscriptions with the same data query tries to load data at the same time, only one thread will actually load the data. The rest of the subscriptions are queued. When the data is loaded all waiting subscriptions will be given the same data set that are then broadcasted to their respective client. |
Default Value |
Property |
Subscription |
Attribute |
subscription.limitation.action |
Description |
Controls the behavior when the subscription.limitation.limit is reached. Allowed values: EXCEPTION, PURGE |
Default Value |
EXCEPTION |
Property |
Subscription |
Attribute |
subscription.limitation.enabled |
Description |
Enables limitation of subscriptions. |
Default Value |
false |
Property |
Subscription |
Attribute |
subscription.limitation.limit |
Description |
Defines a subscription limit. |
Default Value |
100 |
Property |
Subscription |
Attribute |
subscription.log.slow.data.loads.seconds |
Description |
Logs a subscription that has been loading data for more than X seconds at a WARNING level. NOTES: · Any integer less than 1 (or an empty value) will disable the logging. · If a slow data load has been logged and then returns data, a log message at INFO level will be printed stating that a previously logged slow data load has returned data. |
Default Value |
60 |
Property |
Subscription |
Attribute |
subscription.maximum.failure |
Description |
The amount of time a subscription is allowed to fail in a row before it should be cancelled. The number will be reset to zero if data loading is successful. The maximum failure limit is used so that invalid subscription will not loop forever and fill the logs with error messages. The value -1 will disable the fail mechanism. This means that a subscription can fail endless of times and not be cancelled. |
Default Value |
5 |
Property |
Subscription |
Attribute |
subscription.purge.condition |
Description |
Defines the condition for when subscriptions will be purged. Allowed values: NONE, MEMORY |
Default Value |
NONE |
Property |
Subscription |
Attribute |
subscription.purge.condition.memory.threshold |
Description |
Defines a percentual memory threshold for subscription purging, when the subscription.purge.condition = MEMORY. |
Default Value |
80 |
Property |
Subscription |
Attribute |
subscription.purge.enabled |
Description |
Enables subscription purging. |
Default Value |
true |
Property |
Subscription |
Attribute |
subscription.purge.post.restart |
Description |
Option to re-start active subscriptions after purge. Only valid when subscription.purge.scope = ALL |
Default Value |
false |
Property |
Subscription |
Attribute |
subscription.purge.rate |
Description |
Defines a fixed rate, in milliseconds. for subscription purging. |
Default Value |
10000 |
Property |
Subscription |
Attribute |
subscription.purge.scope |
Description |
Defines the scope of subscriptions to purge. Allowed values: NON_PERSISTENT_ORPHANS, ALL. |
Default Value |
NON_PERSISTENT_ORPHANS |
Property |
Timeout Session |
Attribute |
timeout.session.enabled |
Description |
Boolean value stating if timeout functionality should be used or not. |
Default Value |
false |
Property |
Timeout Session |
Attribute |
timeout.session.exception.delimiter |
Description |
The delimiter to use for the usernames stated in the timeout.session.exception.usernames property. |
Default Value |
, (comma) |
Property |
Timeout Session |
Attribute |
timeout.session.exception.usernames |
Description |
Usernames that should be excluded from the timeout functionality. Separated by the delimiter stated in the timeout.session.exception.delimiter property. |
Default Value |
Property |
Timeout Session |
Attribute |
timeout.session.minutes |
Description |
Minutes of inactivity before a user session is terminated by logging out the user. |
Default Value |
480 |
Property |
Timeout Session |
Attribute |
timeout.session.notification.minutes |
Description |
Minutes before a timeout that a notification about session timeout is sent to the user. |
Default Value |
1 |
Property |
WebSocket Connection |
Attribute |
transport.buffer.size.max.bytes |
Description |
Maximum size of message buffer for the WebSocket connections. |
Default Value |
10000000 |
Property |
Attribute |
transport.message.size.max.bytes |
Description |
Maximum size of messages for the WebSocket connections. |
Default Value |
1000000 |
