Session Tokens Not Working in Chrome
Setting the authentication.token.persistence property to SESSION in Panopticon.properties removes the token from the browser if it is shutdown.
In Google Chrome, you can override the session functionality if you select Continue where you left off option in the On startup section. However, if you opt to use session cookies, select Open the New Tab page option.
Steps
1. Open the Chrome web browser.
2. You can either:
· click
to
the right of the Address box and select Settings
· Or enter chrome://settings in the Address box.
3. Scroll to the bottom of the page and on the On startup section, you can either select:
· Open the New Tab page
To use the session cookies.
· Continue where you left off
To override the session functionality.
4. Restart Chrome.
