Altair® Panopticon
Licensing
Licensing within the Panopticon Visualization Server supports the following license types:
q  a volume-based XML file (named PanopticonLicense.xml) which is used to store all license information for a specific customer, must be copied to the designated AppData folder (i.e., c:\vizserverdata)
    NOTE
Starting with 21.2, the newly issued volume-based license file is named PanopticonLicense.xml. For customers with the DatawatchLicense.xml file, it can still be used but it is strongly recommended to rename it to PanopticonLicense.xml.
 Altair  Units license which is available in the Altair License Server you are connected to (local or over the network)
 Hosted Altair Units license
The license file type you will use is delivered separately from the installation packages. Also, license files are required for both the Panopticon Designer (Desktop) and Panopticon Visualization Server components.
   NOTE
  • If you install Panopticon Designer (Desktop) for stand-alone use, it will request activation through entering a separate license file (volume-based or Altair Units) when using it for the first time. If you install Panopticon Designer (Desktop) for use with the Panopticon Visualization Server component, the Panopticon Designer (Desktop) software will retrieve its license automatically from the Panopticon Visualization Server.
  • In the Panopticon documentation, HyperWorks Units (HWU) and Hosted HyperWorks Units (HHWU) are now named Altair Units and Hosted Altair Units, respectively.
In the Panopticon product, these license types are still named HyperWorks Units and Hosted HyperWorks Units.
For more information on Altair Units, visit https://www.altair.com/altair-units/.
