Silent Install Through Running a Batch File
Running the silent installation through a batch (.bat) file is highly recommended for large scale deployment as the batch file can be easily executed on all machines.
NOTE |
Make sure the Panopticon Designer (Desktop) MSI file location mentioned in the command line is accessible.
1. Create a new text file and copy the preferred command line mentioned in the previous section:
msiexec.exe /i <path to package> [/q{n}]
Sample command line:
msiexec.exe /i “[path to DatawatchDesignerx64.msi]”/qn
Example:
msiexec.exe /i “C:\Users\User\onlinehelp\DatawatchDesignerMSI_x64_16-2-0\DatawatchDesignerx64.msi” /qn
2. Save this as a batch (*.bat) file.
3. Double-click this batch file as an Administrator.
