OneTick & OneTick CEP
NOTE |
For version 16.7.0, the OneTick connector is built and tested against version 1.17 of the OneTick Client.
For OneTick, manually copy specific dependency files from the OneTick installation. (e.g., C:\omd\one_market_data\one_tick\bin) to the Plugins folder.
This is available by default at:
C:\Program Files\Datawatch Desktop\Designer\Plugins\Panopticon.OneTickPlugin
The specific files to be copied are:
q Csomd.dll
q Csomd_native.dll
q Libonetick.dll
In addition, the following files are required for streaming continuous query support:
q msvcp100.dll
q msvcr100.dll
Finally, a new folder titled config, must be created under the Plugins folder.
e.g. C:\Program Files\Datawatch Desktop\Designer\Plugins\config
And the file: windows_tz_mapping.dat
Copied into it, from the OneTick folder: C:\omd\one_market_data\one_tick\config
The OneTick connector also requires that the environment variable: ONE_TICK_CONFIG
Has been configured with the path to the required config file.
Example:
C:\omd\client_data\config\one_tick_config.txt
And that the OneTick configuration file has entries for Windows OS time zone mapping and information.
Example:
WINDOWS_TZ_MAPPING_FILE="C:/OMD/one_market_data/one_tick/config/windows_tz_mapping.dat"
WINDOWS_ZONEINFO_PATH="C:/OMD/one_market_data/one_tick/config/zoneinfo"
