Text
The Text connector allows the retrieval and processing of delimited Text files (such as CSV, TSV, and so on), either from a disk or from a defined URL.
1. Select Text from the Data Sources pane. The Text Settings pane and the retrieved Text source are displayed.
2. Enter the Name of the Text data source, then click
3. Select the Text File Source.
The standard settings controlling how the text file is parsed, is listed.
These include:
Property |
Description |
Skip First N Rows |
Specifies the number of rows that will be skipped. |
Data Type Discovery |
Specifies how many rows from the text file should be used when automatically determining the data types of the resulting columns. |
Text Qualifier |
Specifies if fields are enclosed by text qualifiers, and if present to ignore any column delimiters within these text qualifiers. |
Column Delimiter |
Specifies the column delimiter to be used when parsing the text file. |
First Row Headings |
Determines if the first row should specify the retrieved column headings, and not be used in data discovery. |
4. Click
to the fetch the schema based on the connection
details. Consequently, the list of columns with the data type found
from inspecting the first ‘n’ rows of the input data source is populated
and the Save button is enabled.
5. You can also opt to load or save a copy of the column definition.
6. Click
to add columns and specify their properties:
Property |
Description |
Name |
The column name of the source schema. |
Column Index |
The column index controls the position of a column. Must be >= 0. |
Type |
The data type of the column. Can be a Text, Numeric, or Time |
Date Format |
The format when the data type is Time. |
Enabled |
Determines whether the message should be processed. |
To delete a column,
check its
or
all the column entries, check the topmost
, then click
7. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
8. Tap the Preview Selected Data Source slider to turn it on.
9. Set the row limit of the data set.
10. Click
to display the data preview.
