Merging or Importing Workbooks Using the Toolbar
Existing workbooks can be imported into another open workbook, merging their dashboards together.
For example, the How to Actions workbook has eight dashboards, while How to Drill has two dashboards. Follow the steps below to import the eight dashboards and the associated data tables of How to Actions to How to Drill.
1. Check the boxes of multiple workbooks either:
· on the Grid View, or
· on the List View
The
Merge
icon on the toolbar is enabled.
2. Click
. The Select to Merge Target
dialog displays.
3. Select the target workbook (i.e., How to Drill) where the dashboards will be imported.
4. Click
Both workbooks are now available on the Quick Access pane.
The dashboards and data tables from How to Actions are now added to the How to Drill workbook.
NOTE |
Dashboard parts and actions, that reference a data table that needs a new Id/name, will update the data table reference to point to the correct one.
