Adding a Series Legend
The Series Legend displays configured reference lines, their associated labels, and visual members.
1. After double-clicking or drawing a rectangle
on the dashboard canvas, click
on the Select Part pane
then click the Series Legend
icon.
The Series Legend Settings pane is displayed, and the Series Legend part is added on the dashboard canvas.
2. Select any of the available parent visualizations from the Linked Part drop-down list.
The legend is now connected to a parent visualization. It will retrieve the reference line listing from this visualization and display the constituent reference lines in a vertical column along with their associated labels.
NOTE |
In the example above, for SMA5, SMA10, SMA20, the square represents the configured Custom Single color for each visual member.
For the BBU20, Price and Volume members, there is no configured Custom Single color.
Setting the Custom Single color for the visual members helps display the Color Legend for layers in the Combination Graph, in cases where the Color variable is not used. Furthermore, the SMA10, SMA5, and SMA20 are the reference lines added under the BBU20 visual member.
3. On the Series Legend Settings pane, tapping the Enable User Interaction slider enables check boxes of the visuals and reference lines and users can check or uncheck them to filter which ones to displayed in the parent visualization.
For example, if BBU20 is unchecked:
The visualization and reference lines for BBU20 will not be displayed.
If Volume is unchecked:
The visualization for Volume will also not be displayed.
4. Tapping the Show Visual Members slider allows users to display visual members in the series legend.
Disabling Show Visual Members hides the visual members in the series legend. However, the reference lines will still be displayed.
5. Tap the Display in PDF slider to include this dashboard part in the PDF output.
6. Click the Save
icon on the toolbar to save the
changes.
When
saved, the
notification is displayed.
