Icons Variable Configuration
You can drag and drop numeric and text columns onto the Icons variable. The options available in the configuration pane will depend on the type of data in the column. You can also assign multiple icons for each single source column.
The Heat Matrix, Treemap, and Tablevisualizations have the Icons variable.
1. To associate columns from the data table, drag and drop them to the Icons variable drop area. Select a numeric column to display the corresponding configuration pane.
This displays the configuration pane.
2. Enter the label of the Icons variable in the Variable Title field.
You can parameterize the variable title to support dynamic schema in the dashboards.
3. You can also change the column to the be used as the Icons variable from the Column drop-down list.
4. Specify an aggregation method in the Aggregate field.
The default is Sum.
The Icons variable also supports a number of other aggregate types:
· If you set the aggregation method to Cumulative Sum, Cumulative Sum By Max, Intercept, Percent ot Total Change, Percent of Weight Parent, Percent of Weight Total, Ratio, Slope, Weighted Harmonic Mean, Weighted Mean, or Weighted Sum, the Weight Column drop-down list is enabled and displays a list of numeric data columns in the selected data table that can be used as the weight column for the aggregate.
· If you set the aggregation method to Percentile, the Percentile field is displayed. Specify the value that can be used to calculate the value of the selected percentile.
5. The Format field lets you specify the format that numbers will be displayed in. Panopticon uses the same formatting rules as Excel.
6. Select the Divide By value to divide a number:
· 1
· 1000 (by a thousand)
· 10000
· 1000000 (by a million)
· 1000000000 (by a billion)
7. Click the Add Icon
button
to complete the task.
Clicking the Add Icon button with a numeric column displays a new section where you can specify:
8. Enter the Label of the new icon.
9. Specify the numeric range (Min and Max) to display the icon. Leaving the Min and Max fields empty implies no limit.
10. Select the Icon from the drop-down list.
11. You can also opt to select an External Image.
Click Choose File
to display the Open
dialog and select the icon that will be used.
12. To add more icons, click the Add
Icon
and
repeat steps 8 to 11.
13. Click the Save
icon on the toolbar.
When
saved, the
notification is displayed.
You can add Icons based on text columns in a similar way.
1. To associate columns from the data table, drag and drop them to the Icons variable drop area. Select a text column to display the corresponding configuration pane.
4. Click the Add Icon
button
5. Enter the Label of the new icon.
6. The Raw Pattern field lets you specify a text string. When a node in the visualization matches the text string, the corresponding icon is displayed. Leaving the Raw Pattern field empty creates a match on non-empty strings.
7. Select the Icon from the drop-down list.
8. You can also opt to select an External Image.
Click Choose File
to display the Open
9. To add more icons, click the Add
Icon
and
repeat steps 5 to 8.
10. Click the Save
When
saved, the
