Modification of the Column Names
The name of columns retrieved from the data source can be modified.
1. On the Data Sources pane, click a data source to display its settings.
2. Click Columns. The Columns pane displays with the list of available columns in the data source.
3. Select the column name that you want
to modify and enter the new name and click
Once
the column name is modified, the
button
is displayed. Click this button to revert to the original column name.
4. Click
. The new column name is displayed on
the Data Preview.
