Deleting a Filter
When you delete a filter, Monarch Classic removes the filter name from the Filters dialog. If the filter is applied to the table at the time it is deleted, Monarch Classic re-displays the table using all the available records.
Select Filters from the Table Design ribbon.
Select the filter you wish to delete on the Filters selector.
Select Delete from the Table Design ribbon.
CAUTION: Monarch Classic has no undo facility. Once you have pressed Yes, then you cannot reverse the change. Prior to pressing Yes, however, you can press No to reverse the change.
