Altair® Monarch®
Editing a Template Definition
You can edit a template to change its name, type, trap, sample data, or field definitions.
  1. Go to Report Design.
  2. On the Report Design interface, select the template you wish to edit on the Templates selector.
  3. The selected template's properties are displayed on the Template Editor. Make the desired changes to the template definition.
  4. Commit the edits by doing one of the following:
