Opening a Model Before a Data Source
You can open a model before its data source and manipulate its objects (e.g., templates, calculated fields, etc) in Table View or Summary View.
Go to File tab, select Open, then Model. This opens a model only.
Select the window you want to manipulate the model's objects in by selecting the Table View or Summary View.
Note:
If you make any changes to the model, when you end the Monarch Classic session (or close the model), you will be prompted to save them. Select Yes to save the changes or No to cancel them.
