Function: Page
Returns the page in the report file of the last detail line for a record.
Page()
Arguments
None.
Return value
This function returns a number.
Calculated field example
The following expression returns the report page and line for each record, as a string: "Page: "+LTrim(Str(Page(),7,0))+" Line: "+LTrim(Str(Line(),3,0))
The output of this expression is in the form: Page: 125 Line: 17
Filter/Find example
This function might be used along with the Rand() function to perform auditing of report data, but otherwise has no practical value in a filter expression.
