Altair® Monarch®
Duplicating a Table
You can duplicate a table to create a copy of the table in the Prepare Window.
After duplication, you can then carry out operations on the duplicate without changing the original table.
  1. On the Prepare Window, click the drop-down arrow beside table you would like to duplicate and then select Duplicate Table from the context menu that displays.
    A copy of the table is created and displayed on the Table List panel.
    The new table is named <Table Name>n, where n is a number that indicates how many copies of the table there are.
  2. Rename the table as needed.
Related Links
